1 - 9 of 9 Posts
Hi, having trouble figuring out which of these is the SPOUT connector? Anyone know for sure? 1995 Ford E350 van with the 460. Thank you!
92470
92471
92472
Check right below the distributor. 2 wires goes into the connector and what appears to be a plug on the other end.
On these, it's not near the distributor - it's near the icm. I just don't know which of those are correct. Thanks!
1 and 2 look like it
No on 3.
How far is #2 from the ICM and heat sink?
SJ
used 2b RHP
A post on FTE said Ford moved them to the left fender apron-firewall area. A picture showed 2 red wires and a grey plug/jumper in the connector.
You can trace it back to pin 36 on the PCM per these diagrams:
Factory Powertrain Manual Page 516:
92527
This leads us down the rabbit hole that is the Factory Electrical Troubleshooting Manual. On Page 27-7 & 27-8 they break out the PCM pins and show pin 36, traces to circuit 929 (PK) "pink" wire. This leads us to page 21-1 and then to 151-8 A-10 to locate it right next to the ICM.
92528
92529
C165 in this diagram ... Pink wire in and out of the connector. Cheers!
1 - 9 of 9 Posts
