97 F250 HD 460.
About a year ago i had a whistle at idle, let my mechanic have it, it was a bad TB gasket.
About a month ago it started again. So i changed the gasket and it didnt seal. Tried 2 gaskets, nothing, got pissed and sprayed copper sealant around the outside of TB till it shut up. That lasted a week.
So i pulled it back off cleaned everything up and put 1 gasket on (the right way) torqued the bottom 2 bolts first (it seems to not seal on bottom) and its been fine till yesterday. I towed 6300lbs or so 35 mi and when i pulled in the driveway i heard it. Did what i had to do, (truck sat for about 3 hrs), fired it up it wasnt whistleing at idle, but now it does it (loudly) about 3500rpm.
WTF is causing the TB gasket to do this? It continues running fine but its annoying as hell. When i had it off i used a straight edge and nothing seems warped....
Any ideas???
Any ideas???
