Im building a large 460 and want to use the blue thunder A (ford port) heads but dont know if they will fit into the engine compartment since the ex. ports have been moved up 5/8 inch on those heads. I know the SVO heads will fit but they are no better than iron CJ. Thanks in advance
Author Reply
RJP
(no login)
198.81.17.179 Aluminum CJs
No score for this post November 12 2001, 11:38 AM
Are better than the iron CJ heads. Personal experence but no dyno sheet to prove. Replaced a pair of iron heads with the aluminum on a flat bottom V-drive, boat left harder and pulled 3-400 rpm more than with the iron CJs, same size valves/ports. Exhaust port is improved over the origonal CJs.
Gary
(no login)
12.13.226.11 PORTS
No score for this post November 13 2001, 10:35 AM
THOSE PORTS AREN'T JUST MOVED UP THE FLANGE IS AT A DIFFERENT ANGLE TO. SO HEADERS BECOME A REAL CHALLENGE.
Bob
(no login)
204.186.209.95 B/T heads
No score for this post November 14 2001, 1:06 PM
The Bluethunder heads are a great piece but can be a difficult fit in this car! Stock parameter heads are tight! With a modified shock tower it could be done!
Consider either the B/T stock port location 460 head or the Edelbrock head!
Check with D&D AUTOMOTIVE SPECIALTIES
They are dealers for the heads & I think the swap parts too!
They also have a ton of trick 460 stuff
phone 610-432-0041
e mail [email protected]
web site www.mspmall.com/ddautospec
Author Reply
RJP
(no login)
Gary
(no login)
12.13.226.11 PORTS
Bob
(no login)
phone 610-432-0041
