Have BBf parts on here for sale. Couldn't find what I wanted in a 302 so trying 351w. Need rpm intake. Cam maybe pistons standard or .030 6183834738. Ed
parts
I got several parts for 351 10 probe pistons .30 new, roller cams, edelbrock heads, aluminum water pump, cranks rods it would be for 2.75 mains
256-717-5004
351w build
Im using 65 289 heads for compression with chevy valves that will flow what the old edelbrocks would 230cfm or more. Im using a tight lobe seperation cam that peak early and make alot of low and mid range torque so i need a rpm intake, this will also allow me to use the bigger 850 annular carb i got since the intake slows down the flow i suppose but they love big carbs and single plains dont. with about a hydraulic around 234 degrees at .050 on a 106 lsa it will drive decent and pull to 6000 rpms easy. This is just a thrown together motor to cruise.
