Working on a big block in a 4x4. Owner bought it at an estate auction so nothing is known about it. It sounds good, runs good but it uses a quart of oil in 500 miles. I ran it hard up and down the road with a friend following and It never let out any smoke. I took the plugs out, they looked fine. I did a cylinder psi test, all are good. For the hell of it I leaked it down, once again, it's fine.
It definitely has a high psi oil pump. Cold Idle around 70 psi, hot around 55 psi. I took the breathers off and both have a milky film in them looking from the underside up into the breather. It's a dirty, somewhat leaky engine but nothing has dripped on the floor under it.
My thought at this point is that oil pump. With that much psi could it be creating so much windage that it is coming out the breathers and causing the leaks ? At first I thought it was strange there was no pcv on it, but maybe there was one at one time and it was removed because of plugs fowling.
