anyone looking for a windsor cam , i have a brand new hydroilc roller cam cost new was 270.00 will sell for 150.00 shipped in the usa , 517/285/4751 [email protected] located in michigan thanks for looking Phil specs are
Serial # Y 1507 Spec Card# 028030
Part # 35-000-8 CAMSHAFT, FW FORD 351W/302HO HR/SR
Core C35-8P CAMSHAFT BLANK, FW FORD 302 H.O AUST
Grind # FW 3398F /3385F HR114.0
DURATION @ .050 INTAKE 240 ROCKER ARM RATIO
VALVE ADJ INTAKE .000 DURATION @ .050 EXHAUST 252 INTAKE 1.60
VALVE ADJ EXHAUST .000 LOBE LIFT INTAKE .3410 EXHAUST 1.60
VALVE LIFT INTAKE .545 LOBE LIFT EXHAUST .3410
VALVE LIFT EXHAUST .545 LOBE SEPARATION 114.0
DURATION .006 INTAKE C/L 110.0
TAPPET LIFT INTAKE 293 CAM ADVANCE 4
TAPPET LIFT EXHAUST 305 HYDRAULIC Y
VALVE TIMING .050 OVERHEAD CAM N
VALVE OPEN INTAKE 10 JOURNAL DIAMETER STD 2.036
VALVE OPEN EXHAUST 64 RECOMMENDED VALVE SPRINGS
VALVE CLOSED INTAKE 50 DEPARTMENT P
VALVE CLOSED EXHAUST 8 SPC INSTR FOR CUSTOMER
