1 - 6 of 6 Posts
I am in need of a 140gph or larger Mechanical fuel pump ASAP !
Jim
this is directly off the holley site
•High Output Fuel Flow
•Flows 130+ GPH Free Flow
•Shutoff Pressure Pre-set from 7.5 to 9 PSI
•Fuel Pressure Regulator is Required (Recommend Holley p/n 12-704)
•Heavy Duty Construction For Continuous High RPM Operation
•Redesigned High Flow Valves Always Ensure Adequate Fuel Delivery
•Fuel Body Casting Can Be Rotated to Accommodate Various Plumbing Situations
•Inlet & Outlet Tapped For 3/8" NPT
asking $75 for it
What is the pn# ?
Thank you
Jim
1 - 6 of 6 Posts
