1 - 11 of 11 Posts
i am looking for a standard dove port tunnel ram lower to use in my fuel injection setup. upper half and top is not needed but would be acceptable if thats what you have.
please let me know what yall have got
thanks,
barry
CHECK
E B-Y
THEY HAVE BEEN A LOT OF THEM ON THERE
R--e J--K . COM
THERE IS SOME ON THERE
FROM WHAT EVERY ONE TELL ME ALL THE TUNNEL BASE IF ALL THE HEADS
THEY ONLY MADE 1 STYLE
BUT
YOU DO HAVE A CHOICE OF
WEIAND
or
OFF IN HOUSER
thanks,
barry
BBFmavrick
Forum Contributor Join Date: Jan 2007
I SEEL THIS LISTED ON HERE
SO I THOUGHT YOU MITE LOOK AT IT
Tunnel Ram
Guy's ,
I'm posting this for someone else ,I hav'nt seen it so if you have any ??? call him .
Offy Tunnel Ram w/single Dominator top
SCJ ports
Good condition
$175
1-410-482-7229 ask for Rodger. He lives in Greensboro Maryland
Rick
466ci. w/Dove C's ,C6, 4.30 w/spool, 4 link, #2970 Best ET 10.12 w/this combo
Hi, Are you running a Enderle Injector Hat??
It doesn't have dove ports but SCJ but there is the enderle modified blue thunder manifold setup for a injector hat, or blower if you get a plate and use the extra 8 outside bolts.
I think the part number is enderle 460BT or something. It's not cheap tho but the hat bolts right on with a 2 or 3 inch spacer
Adam
I am running efi and would build the intake plenum and weld in injector bungs myself.
BBFmavrick
Tunnel Ram
Guy's ,
SCJ ports
Good condition
$175
Rick
thanks for the heads up on that one George but i am really looking for an intake with dove sized ports.
thanks,
barry
I have a new 5993 Weiand that I've had on the shelf for a while but It has never been run or modified in any way. If you are interested, give me a call at 931-607-6015(cell) or 931-939-3664(home).
Thanks, Mark
THE WEIAND THEY SAY HAS THE SMALLEST PORTS
BUT I WAS TOLD THAT THE OFFIE FLOW BETTER WITH OUT PORTING
AND
THEY BOTH HAVE TO BE PORTER TO FIT CJ or SCJ HEADS
i was under the impression that all of the offys had CJ szed ports?
barry
1 - 11 of 11 Posts
