1 - 12 of 12 Posts
I know this is prolly useless but thought I would give it a long shot. I had my pistons already but when the machine shop went to do the finish hone on my block they found a hot spot they had to get out and had to go to far for my pistons to work. Now I am facing buying a new set of custom A460 Pistons. My finish bore is 4.615, 6.7 Aluminum Rod, 4.50 Stroke, and the compression height for a standard deck and they have to be for nitrous. The pistons I have are diamond and are for above with a back cut .043 top, D Wall Second, and standard oil, 4.596 in size, flat top, gas ported, with A460 Valve Reliefs. I will take 400 or best offer if anyone needs them. I can get pics if someone is interested.
U may want to contact 017stosh another member on here he has some A head pistons forsale b/c I bought his heads but the pistons were TOO big for me, he still had them as of fri when i talked to him last if u cant get him let me know I ll get you his number
thanks josh
thanks josh
Thanks, I will look him up.
Are these new or used??
Used. But another member on here called Eric at Diamond and he told him a different story on the ring pack with the build number I gave him. Let me find out what the crap is going on. Eric told me the rings were .043 Back Cut X 170 Top .043 D Wall Second and 3/16th oil ring but he told this guy it was 1/16th 1/16th 3/16. So now I am really confused. I got the pistons with a package I bought from another racer on here with the rods cam heads etc and now the bore is too big.
It might be more economical to get another block and have the machine shop start over.
Hope this helps,
LOL, I just spent over a thousand bucks on the block machine work and rotating assemble balance. I can't see buying another A-460 block instead of buying new pistons.
Here is what Eric at Diamond told him about my build number on the pistons.
Bore is 4.603" finished bore
.007" piston to wall @ 4.603" - measure point .850" below oil ring groove actual piston dia. = 4.5980"
Flat top valve reliefs = 2.6cc's volume. .290" down top ring
1/16 x 1/16 x 3/16 ring stack - uses a support rail
.990" x 2.930 pin double spiral lock
1.310" CD
pockets depths = .200" deep intake, .070" deep exhaust
643 grams as delivered.
aa
So what you got is a used set of A Head pistons that will make 599 inches and about 13.3 to 1 CR with 78 CC heads swinging on 6.7 rods and a 4.5 crank .......pretty close anyway
How used are the pistons, have they been measured for round and consistency from piston to piston ??
Discussion Starter #12
Yea you about got it lol. No I haven't measured or anything like that but if your interested I can send them to you and if you like them you can pay me a fair price, if not you can send them back.
1 - 12 of 12 Posts
