currently looking to purchase a set of 8 pistons for a 429 or 460 crank.
looking for flat top pistons that will be ran with D3 heads and a '71 block.
want to get around 10.1 comp or a little more to be pump gas friendly.
ideal would be a forged or hyper piston flat top bored .040 will be going on stock 1971 rods.
anything over stock bored and flat top!
new or barely used,let me know what you got thanks!
I have a set of dish and a set of dome. Both set new in box, speed pro forged. they are .060 though. $300 for dish and $350 for dome. Dome are floating pins also dish are press fit. I know you want flats Just seeing if you were Interested.
do you know what compression ratio these will give me using the d3ve heads? and also the d0ve-c heads?
i'm fine with .060 over bore,just need to know what comp ratio it will land me on with the heads i listed..
and last are they for the 460 crank or the 429 crank?
where are they located?
thanks court
pistons
hey i have a set of 30.over flat tops, new with rings wiesco with pins locks iv got 450.obo on them 460 crank stock rod. thanks
