1 - 11 of 11 Posts
Must be C8AP upper/ C7AP lower casting # 's , Detent in the valvebody .,I'll Pay pal you $100 ea you pay shipping ( USPS nornal chage to send is $22.00)
Frank
Frank, A friend has some valve bodies from old FE c6's. If they are the right castings he is going to let me have them so I can get one of your trans brakes.
I will see if I can check them out this weekend.
mike
Yes were the detent is is critical ,I need the ones with the detent in the valvebody ,theD2Ap's are the same valvebody but the detent is in the case and it does't work because when you bolt it down it can move 1/8" forward or rearward which can cause 2 gears appling at the same time and not a clean shift
Frank
'68-'72 it's easy to tell if it has the right valvebody as the imput shaft fit's in both ways in these year trans
Frank
1 - 11 of 11 Posts
