1 - 3 of 3 Posts
Hey guys, I'm looking for a decent set of D3VE or D0VE heads that I can rebuild for a project I'm working on. The ones I have are cracked between the valve seats and every head I've pulled off a junkyard car around here has been rotted so bad that they're not worth the cost of fixing.
I'm in Michigan, would be great if I could pick them up but I'd be willing to have em shipped if it was reasonable.
Thanks guys, Doug.
Which would you prefer, I have both. :lol: C9VE with larger ex valves and standard intakes, and a set of D3's the same way with the Crane rocker conversion. Both are ready to install with some minor cleaning up in the ports and chambers. Complete rebuilt with new seats and guides and good valves (some new). I will need to look which heads have the Crower springs and which have the Comp springs, but they are new also and set up for a good hyd cam. I believe they are capable of .600 or so lift. I will PM you a cel # if you would like to call me about them.
1 - 3 of 3 Posts
