1 - 6 of 6 Posts
This might be a longshot, but this is what I need. Also, I hear that the manifolds from a 460/429 will work on this engine, is that true? I might also be interested in a passenger car manifold as a last resort, but I would rather try to replace it with the same part.
I can be reached at 213.712.2334 or 714.649.3007. Will pay cash and pick up in the Socal area, let me know what you have.
Thanks,
Seth
Had a set not long ago...pretty sure I tossed 'em, but I'll double check over the w/e.
The passenger car manifolds for the carburetted pass car engines (1968-1986) will indeed bolt to the F600's 370/429's cylinder heads. Where the headpipe collector is (compared to the truck's manifold) may or may not be the same...I don't know.
Paul
Paul,
If you could find them that would be great, I will definitely buy them from you. Or if you know of where to find another set that would be helpful as well.
Thanks,
Seth
Will check, i have a pair of 460 heads off a truck, if my memory serves me the exit's were tilted down about 45/60 degree dumping out at the rear, still had the heat shields on them and still bolted on the heads. this is a busy week-en, will do my best to dig them out.. will this help????Ed :wink:
Seth, checked and found ex-manifold's, nice shape. studs need replaced, plug sheldes and driver side heat sheld for air cleaner all in good shape, took pix, if interested let me know, will send pix. Ed
1 - 6 of 6 Posts
