1 - 9 of 9 Posts
Looking for that california 460 efi timing cover to mount that sensor on.
Todd
picture with the added bolt locations for the sensor mounting.
There is one on ebay for $350. I need one too but can't go $350 when you can get a complete MSD adjustable crank trigger setup for almost $100 less that I am told will do the same thing and its pure bling. I still need the 4 vein crank adapter too if I go with the factory stuff. Anyone have any?
yea that is too much for me also and that one was cracked and repaired, way to much $$... are you going the MSD route?
I am looking for the factory stuff first, but if I can't find it, I will go with the MSD setup, if it will work with the factory mass air computer. I read somewhere that it will work, but I can't seam to locate that bit of information and I have been searching a couple hours.
Timing cover
I have one if you haven't found one yet. It's been cleaned, bead blasted & had the casting flash smoothed down a bit. I was going to use it on my 521, but decided to stay with my old one instead because it's already polished. I have about $100. in it, I'd sell it for that plus shipping which it should fit in a large USPS flat rate box which costs $15. Let me know if your interested.
1 - 9 of 9 Posts
