1 - 6 of 6 Posts
I have a set (center 3 caps only) of Mondello main cap straps with studs that I am no longer going to be using.
The caps are .875" thick and have .125" registers on each side.
I recently purchased these, but have decided not to use them at this time.
If you think they'll work for you, I will sell them cheap. The studs (6 long and 4 normal length) do not have nuts or washers.
Hi Greg,
Was looking more for a 4 cap set, but sending you a PM - may be able to use yours on an upcoming project.
Thanks,
Glenn
Glenn, I tried to send you a PM but it would not go thru.
Anyhow, I have another guy interested in them who got in just ahead of you. If he passes on them then you're next in line.
I paid 100.00 for these, and have had them for two weeks. My build changed and I won't be using them, and I'd be willing to let them go for 100.00 shipped.
Thanks,
Greg
Glenn,
The other guy decided not to buy the straps....But, now I have changed my mind again and I'm going to use them after all.
Sorry man, and good luck on your search.
Greg
Greg - thanks anyway.
I think I might heed what others here have said (and common sense) and just use the right block for the application to start with...
Glenn
1 - 6 of 6 Posts
