1 - 6 of 6 Posts
Kind of a long shot, but does anybody have an adapter plate and flywheel spacer lying around to bolt a powerglide up to a 460?
I've got one but it's not in the greatest shape. The holes where it mounts to the block are all clean and good, but the holes where the studs go through to mount the tranny are worn pretty good as it was used in a high horsepower application. If you know how to weld aluminum it would be a small job to fix. Comes with all bots, studs and crank adapter. The spacer is built onto the flexplate. $60.00 for the adapter kit, $100.00 for the flexplate. The flrxplate is a JW "The Wheel" and is in perfect condition, internal balance with an expired SFI. Shoot me a PM if you're interested.
1 - 6 of 6 Posts
