1 - 10 of 10 Posts
to make a long story short, My C8VE heads are shot, and after spending ALOT getting cast iron welded on they are still not useable, so Im needing a set bad, Id like the smaller chamber heads, (im using Probe SRS flat tops and Scat 4340 H-beams) I am tight on cash right now so I dont have alot to spend, I was wanting to go with the TFS street heads but thats not possible at the moment.
I do need a set of heads that have adjustable valetrain, (solid roller) and Id like a set with smaller chambers, ported ok, I will be bracket racing, http://www.na-motorsports.com/Tracks/VA/MotorMileDragway.html
Let me know what you have,
Thanks, Tim
Have a set of stock heads
I have a set listed below under For Sale- Several parts, they are C8ve small chamber heads, complete w/ stock valves/springs, not ported resurfaced to .015 I believe, according to stamping on gasket surface. screw in studs w/,manley 5/16 guideplates. I bracket raced these heads to 11.55 @ 116mph
1 - 10 of 10 Posts
