Status
Not open for further replies.
As title states, want good condition ultrabell to adapt AOD to big ford. Doesn't need sfi sticker or cert. Cheaper the better, of course! Just has to be in good usable condition.
Edit: Nevermind. I found the 4r70w and AOD front pump bolt pattern is different and bellhousing depth is different too. One would need to swap the 4r70 guts into the AOD case and then use the ultrabell to make it work... and then it's pretty much a beefed up AOD as the valve body would have to be AOD.
Status
