1 - 10 of 10 Posts
Looking for a mild cam for 460 (edelbrock performer plus or similar), pre emissions ('71) timing gear set-FOUND
set of good headers (hooker, L&L, etc) for '76 2wd truck.-STILL LOOKING
UPC:090127606537
Cam Style:Hydraulic flat tappet
Basic Operating RPM Range:2,500-6,500
Intake Duration at 050 inch Lift:241
Exhaust Duration at 050 inch Lift:249
Duration at 050 inch Lift:241 int./249 exh.
Advertised Intake Duration:284
Advertised Exhaust Duration:292
Advertised Duration:284 int./292 exh.
Intake Valve Lift with Factory Rocker Arm Ratio:0.582 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio:0.600 in.
Valve Lift with Factory Rocker Arm Ratio:0.582 int./0.600 exh.
Lobe Separation (degrees):110
Computer-Controlled Compatible:No
Valve Springs Required:Yes
UPC:090127606537
Yeah looking for a mild cam thanks
I think I might have everything that you are looking for. I will be back home Monday. I will check it out then.
1 - 10 of 10 Posts
