429/460 SCJ, CJ and other
HI-PO Parts
10- D0OE RODS $15 ea
12- D0OE-A RODS $10 ea
1- 4U 429 CRANK $100
1- D1VE BLOCK, 2BOLT, THIN WEB $150
1PR- D0VE-C HEADS, 75.8cc, SCJ VALVES (2.245 INT/ 1.725 EXH), W/ SCREW IN STUDS, GUIDE PLATES, SET UP FOR .550 LIFT SOLID CAM $450
1PR- D0VE-C HEADS BARE (some grinding done on one) $200
1PR- D0OE-R (SCJ) HEADS, 73.5cc, SET UP FOR .796 LIFT ROLLER CAM SOLD
523 STROKER RODS, PISTONS AND RINGS CALL FOR INFO $400
7- 523 STROKER PISTONS $200
1- CANTON FRONT SUMP PAN W/WINDAGE TRAY AND PICK UP $250
429 +.040 OVER, 12.5-1 DOMES( if using D0OE-R heads),ARP HEAD STUDS, BUILT ON A D1VE BLOCK AND 4U CRANK, D0OE RODS, ALL FRESH IN SPRING ’06 $1500
16- 8.550 LONG COMP CAMS 1 PIECE, 3/8 PUSH RODS(70-74 scj/cj length) $100
16- 8.700 “ “ “ “ “ “ “ “ (68-69 429/460 length) $100
1- SET ARP HEAD STUDS COMPLETE $90
13- COMP CAMS GUIDE PLATES $5ea
1- OFFENHAUSER 2X4 TUNNEL RAM, SCJ PORTS, DRILLED FOR INJECTION AND FOGGER $150
1- OFFENHAUSER SINGLE 4BBL $150
1- D4VE 4BBL INTAKE $40
1- D6VE “ “ $40
1PR D3VE HEADS BARE, 91.4cc, 2.08 INT/1.66 EXH $75
1 SET SVO ROLLER CAM BEARINGS $50
1 SET SCREW IN FREEZE PLUGS $25
1 SET CRANE ROLLER ROCKERS W/ LOCKS $90
1 SET COMP CAMS PRO MAGNUM ROLLER ROCKERS W/LOCKS $200
I WILL MAKE PACKAGE DEALS IF TRYING TO PUT TOGETHER WHOLE MOTOR WITH WHAT I HAVE. WILL SEND PICS OF ANY ITEM OR CALL FOR MORE INFO ON ANYTHING.
BUY ME OUT AND IT ALL GOES!!!!! MAKE ME AN OFFER!!!
JEFF SMITH (501) 988-9994 HM, (501) 993-4633 CELL OR [email protected]
