My victor intake ports dont match up, was told its CJ size ports? So I need something that will line up correctly would like a domi setup but 4150 is alright. Willing to buy or trade my current setup.
580 919 1685
Jake
If the intake in the ebay auction above doesn't work out, the Torker II or Track Heat intakes are what you need. Neither are Dominator, but you can run an adapter if you already have the carb, or you can get yourself a 1050 4150 style carb.
The motor is going in a drag car and I'm running alcohol I already have a 950 4150 carb do you think this is big enough?
I don't see how people can leave that much of a mismatch, Seems like it would create a massive choke point? I would rather not alter the ports of the head incase I ever wanted to run a different intake or sell the heads one day
In many cases flow bench testing dominator adapters on square bore intakes improved air flow. In some cases better than the same intake with a dominator pad on it.
