Looking for solid roller something around 260-270 at.050 and 675-720 lift lemme know if y'all have one
If something in the neighborhood of 257 intake/267 exhaust @ 0.050" with around 0.675" valve lift works for you then check with Vandy. Cam is brand new, less run in an engine for maybe 15 minutes at the absolute most. Only reason for sellling is going to a bigger camshaft.
$225 + actual shipping charges. PM Vandy directly.
Paul
I have a good used Comp #34-720-9 solid roller. It's a symetrical grind with 272* @ .050", .692" lift and a 106* LCA. Advertized to make power from 3,800-6,500 RPM. It's ground to be a Puller/Mud Racer cam. $225 plus the ride.
Rob
