Looking for flat tops with good rods to run with factory heads.
(Need to spin it up to 8k)
Thanks!!
What kind of bore are you working with?
Stock 3.850 stroke x 4.500 bore = 490 CID
4.000 stroke x (+.080) 4.440 bore = 495 CID
4.140 stroke x stock 4.360 bore = 494 CID
Given the RPM, I'd do a stock stroke to keep piston speed down. Some of our lightweight domes in 4.500 bore at $799.95, plus a set of H-beams and a stock crank would be a pretty tough combination for the money, but we could also do either of the other combinations with an offset ground stock crank and some Diamond pistons.
