I need a set of Springs w/ Dampers, Hydrualic tappets, Chrome moly Retainers, 16 pair valve locks, The cam I am using is a 275int/285ext, .510int/.535ext
I need them new or barely used
I may have what you need, I'll check tommorrow, I took a 270 Magnum cam out that has never been run, and it has lifters, springs, retainers and keepers, 10 degree I believe and I am going with a Lunati so if I do not need any them I will sell them.
Its pretty close to your cam, 519 on both sides, its a comp so you can check to see if the springs are the same as you need. I have a fair amount of stuff I may be selling soon if you need anything else. Dan Parker
springs for flat tappet & hydraulic
if you are still looking for valve springs ? i have a set of fairly new in a box comp 972-16 springs . springs was only used in a break in period on a 351c years ago.
I.D. 1.060''
Seat Load 124 @ 1.800
Open Load 278 @ 1.300
Coil Bind 1.195
Rate(lbs/in) 308
also have a set of erson springs part # E915051
you can check out information on these at http://www.american-automobile.com/Erson valvetrain.pdf
very little run time on these as well
pm me if interested....
