Got this one up on RACING JUNK, but maybe one of you guys can use it. Convert your Richmond 5 or 6 speed to the 1979-1983 Ford Mustang size input shaft and use the stock aluminum bellhousing with the McLeod RST twin disc street clutch. McLeod discs are brand new in the box. Input shaft is brand new removed from a newly purchased Richmond Gear trans, part# 7041711-A that I converted over to a different input shaft. Input shaft is 1-1/16 inch x 10 spline and the correct length for the deeper early Fox bellhousing. New discs are $160 each and the input shaft is $340, a total value of $660, and I throw in the shipping to the lower 48 and the alignment tool!
McLeod RST front disc 6919-03
McLeod RST rear disc 6920-03
Richmond Gear input shaft part # 4541810
Email is best: [email protected]
