Confession: I'm having this problem in a Ford 1.6 liter engine, not a 460, but this is a general question that could easily apply to a 460 so please don't throw it out.
For years, I've been seeing a yellow pudding-like gunk in the engine oil that accumulates in the dipstick tube and in a rubber hose I put onto the valve cover vent opening which carries the valve cover fumes outside from the engine. This replace an original hose that used to carry valve cover fumes back into the air cleaner air intake.
When I drain the oil out of the oil pan, I never see this stuff.
I can guess that it is from cooling system water/antifreeze somehow getting into the oil, but I am only guessing.
I've Zyglo tested the cylinder head, the top of the engine block, and even the inside of the combustion cylinders plus I had an engine shop pressure test the cylinder head and the intake manifold and surface grind the head to ensure it was straight. I found a bad gasket on the intake manifold that was letting water get into the combustion chambers and fixed that. So, if it is water getting into the oil, I think the only place left where it could be getting in would be a crack in the block at the bottom of the block's water jacket-do you agree?
Can anyone here please confirm the yellow gunk is most likely water/antifreeze getting into the oil or else give me some ideas of what else might be causing this?
Thanks,
Audioresearch
Thanks,
Audioresearch
