1 - 11 of 11 Posts
I am looking for a tire will will help me get the traction I need in my 66' Mercury 1/2 Ton truck. Street/Strip
Engine (521) should make around 700 H.P. I am using a C-6 trans, but I'm not sure if I am going to use a trans brake yet. Plan is a Calvert mono-leaf, cal-tracs, and sliders in the rear.
The street radials have a better selection of sizes, and since my tire is tucked into the wheel well, width is a concern.
I am looking @ the 30x12.5-15 tire right now, with an actual tread width of 10.9".
Looking for your opinion, suggestions. I would like to get my tire stuff figured out so that I can move on to my gear ratio and converter stall.
Thanks,
Derek.
Super Moderator
That will be a very good tire for you. I didn't run that size myself but it seemed like they were made of super glue.
How much does your truck weigh? I have a trans brake in mine but was never able to use it because of the weight. It is very hard on driveline parts when coming off the line. I do have a 4500 rpm stall that worked well but I would still snap stuff so hitting it at 4500 rpm up on a trans brake never really seemed like a good idea. I also have a 521. Somewhere north of 700 hp. At least according to the times that I ran anyway using the HP calculators. My pig is close to 5000 pounds with me in it. That is very hard to drag race. I'm not sure what I was thinking when I built it.
http://www.MrScharfenberger.com/F100/TruckVideos/F100vs86Camaro.wmv
Im planning on using the m/t 295/60/15 on my deal.
I've got a t brake and caltracs and over 700ft lbs....i can tell ya one thing......ya gotta have a stiff sidewall tire!!
Droppedf100 on here has a late 70s f100 running them in the high 1.4's in 60ft.
Nice!! Thanks for the help guys...
Mr. S, my truck won't be quite as heavy as yours... It should weigh between 3700-4000 lbs. when complete. They were never quite as heavy as those gen. 6 trucks.
MT street radials
DJW check out my video in my signature . I am running 275/60/15 MT drag radials . They hook up real nice , nice enough to pull the front tires and give me a 1.5 60 ft . Motor is 600 hp with a 4500 stall convertor and 410 gears .
im running 275x60x15 in #3870 f1 truck with 490hp by wallace racing calulator for mph. my 60ft r in the 1.5s but when i spray the 275 dont work think the 295x55x15 would help. best et. on motor 11.51 @ 115 at dragweek 2010 in indy handed a 526 hemi roadrunner his a$$
dragweek quickest street rod
2009 2010
2009 2010
You go get em 52!
Thanks DJW . I did a typo , my convertor is a 3500 stall not 4500 . Hit the wrong button .
what is the street-ability like with a 3500 stall? Or is she not street legal?
You go get em 52!
most think it is a sbc till i make a pass then they ask wtf do you have in that truck. and when i tell them its a 460 ford with overdrive they cant believe it. i also have 3500 stall but with lock up. and a little spray lets really run
2009 2010
1 - 11 of 11 Posts
