What is normal practice when zero decking a block?
Does the machinist assemble the short block and take a measurement from cylinder deck to piston face at TDC, or does the machinist take into account the cranks stroke, rod length and piston height to determine how much to remove, without assembly?
The second theory would not be accurate, because the deck height is not always exactly the same on all production blocks, correct?
