'78 E350 460 timing chain upgrade recommendation
17K views 9 replies 7 participants last post by  Fitswell
I had an interesting experience with an aftermarket 3 position double roller timing set for a 460 a few years ago and it's worth mentioning. The set was made where the zero straight up mark was actually the same as the factory RETARD (8 crank degrees) set! I found this right away when I checked the cam timing but if a person didn't it would slip by.
