I'm an Aussie looking at replacing my modified iron heads for a set of allow heads, but I have a few requirements I want them to meet.
I want them to accept my current custom made extractors (2" primaries that are 32" long and 3.5" collectors)
I want them to out of the box, out flow my current modified heads and have the ability to be opened up at a later date if I change to a stroker combination.
I will be using this car on the street as well as the strip, so I'm after something that will work at lower revs also.
I'm also after responses about changing my inlet to a victor jnr
Now my motor was built originally maybe 15 years ago and there are better options out there, but here are the specs at the momment (as best as I have logged them):
Block = DIVE-A2B bored .030”
Heads = D3VE-A2A
Modified by Eddy Woods from The Head Stud
Inlet flow 293 cfm @ .6” lift
Exhaust Flow 162.2 cfm @ .6” (168.4 cfm @ .5”)
Flowed @ 25” H2O
Valves = inlet 2.246” exhaust 1.8”
Valve springs = Crane Dual 120 lbs closed 340 lbs open + crane retainers
Guide plates = Manley
Screw in studs = Manley
Pushrods = Manley heavy duty thick rods
Cam = Crane f246 solid ( part # 351211)
Duration @ .050 246/256
Lift .563”/.583” with 1.71 rocker arms
Operating Range = 3800 – 7000 rpm
Roller rockers = Yella terra 1.73 ratio
Tappet clearance = 0.026” hot
Pistons = TRW Forged 11:1 pop up
Rings = Sealed Power
Conrods = Super Cobra Jet (D6VE-AA) shot peened and ARP rod bolts
Crank = Standard 1974 Nodular Iron (2YABC) 10/10 and balanced and tuffrided
Main Bearings = Michigan 77 -.010”
Gear drive = Milodon Straight cut (14600)
Heads Studs = Arp 155-4003
Main Bearing Studs = Milodon 81188
Oil pump = Mellings High Volume
Oil Pump Drive = Ford Power parts
Sump = High Energy
Gaskets = Felpro
Inlet manifold = portosnic which has been port matched and ported, but when fitted dropped the inlet flow down to 283.1 cfm
Carby = 1050 dominator
The car is an aussie 1970 ZC fairlane which weighs approx 4000 lbs with driver
Auto is C6 full manual and transbraked, and convertor is 3900
Diff is 3.89 LSD but will be changed to possibly 4.5 for track useage
Thaks for any help
Mick
Heads = D3VE-A2A
Flowed @ 25” H2O
Sump = High Energy
Gaskets = Felpro
Thaks for any help
Mick
