Front Timing Cover Oil Dipstick plug
1.8K views 9 replies 6 participants last post by  joeggernaut
#1 ·
#3 · (Edited)
Hi
If you can slide the chuck end of .375 3/8” drill bit, straight in and out of the hole without it binding or forcing it, and without it being overly sloppy. No reason that plug wouldn’t work once carefully pressed/tapped into place.
Edit: Good example of what not to do, see post #5.
#4 ·
Is this a new front cover?
Used with dip stick tube removed or not being used?
"EMC 2006" 3rd place finisher
Custom ground cams
Customized crate engines
ParklandAutoMachine.com
R-H-P.biz
(253)-988-6648
Log into Facebook
#5 ·
Is this the correct plug for the front timing cover oil dipstick tube?
I don't want to tap and thread a bolt.
The dipstick hole plug for the front timing cover is about 3 inches long. This is because there are multiple thru-holes in the cover that must be plugged simultaneously in order to prevent coolant from mixing with the oil.
We have a few spares, call the shop if you care to purchase one. Phone number via the link in my signature line below.
#7 ·
Have you removed the OEM dipstick???
If so you use the item Paul Kane listed.
If not you can remove it or simply use a high quality vacuum nipple on the protruding dipstick tube.
Custom ground cams
R-H-P.biz
(253)-988-6648
Log in or sign up to view
#9 ·
If I may speak for Paul,if you removed the timing cover,you would see the tube going through several holes. If you removed the tube and just plugged the top hole,you will have coolant going in the oil from the lower holes that were left unplugged. In your case,the vacuum tube cap on the top is easiest like Scotty says.
