460 cam options
1 reading
467 views 29 replies 7 participants last post by  The Mad Porter
#1 ·
Hello, this is my first time on here so IDK exactly what I'm doing. That being said I am building a 460 and wondering what cam I should get. The specs aren't going to be anything crazy, it is the 1976 version, so it will have 8:1 compression and I'm going to run rebuilt stock heads and valve train. As for performance parts I'll be running a comp cams double roller pre 72 straight up timing chain set to correct factory retard, edelbrock performer RPM aluminum intake, Holley 750 carb and shorty headers plus other random bolt ons. Given it's bottom end is relatively stock besides being rebuilt what cam would compliment everything nicely without ruining low end torque and vacuum. What duration, lift and if you have specific recommendations. Thanks!!!
#4 · (Edited)
When that engine goes back together it will be 7.7 to 7.9 to 1.
You don't have a lot of options for cam timing that aren't going to kill the bottom end torque needed in your truck.
I generally use our 207 / 219 custom voodoo grind for this type of application. 110 lsa and advanced another 4* over straight up.
If your cylinder heads have OEM springs and umbrella seals you MUST keep lift at less than about .520"
In this case I would use the lower lift comp ex lobes OR a shelf 204 / 214 generic RV cam for lack of a better term.
The OEM cam timing for reference is 193 / 206 on a 113 in at 110 to 113 with a straight up timing set and 118 to 121 with the retarded set. Tolerance variation.
The performance EFI cam of the 90's was 204 / 216 on a 114 which was a good cam for the EFI and that crane grind was similar to the generic I listed.
A properly curved duraspark distributor is an important component.
DO NOT USE THE PERFORMER RPM. The performer is the correct intake here. Block or restrict cross over heat.
A 600 vac secondary properly tuned is more than enough carb.
We recently dyno'd a 1995 EFI take out with 190k miles. 476 tq and 312 hp using 500 cfm at 4100 rpm.
"EMC 2006" 3rd place finisher
Custom ground cams
Customized crate engines
ParklandAutoMachine.com
R-H-P.biz
(253)-988-6648
Log into Facebook
#12 ·
I am not sure, I haven't had it priced. The engine only had around 100,000 miles and it was in an LTD that was treated very well, everything was very good and clean. So I had thought I would use the original pistons just re ringed. Since it was out and I wanted to wake it up a little without doing too much bottom end work, I was gonna de-smog it and add some performance mods.
#18 ·
This is my first time on here yes, but I haven't gone without doing any research or asking questions. Almost all parts I have for it will be going on it, besides that intake which was actually recommended for this build by multiple people for some reason. I am not very deep in yet and I have a lot of parts from other engines too, nothing I have is required to be put on this engine. I will likely build more of these engines eventually in the future also, when I have more knowledge on everything I'm doing, given I'm not very old if you couldn't tell.
#27 · (Edited)
HI,
Yes you want a split lift on the BBF's.
I ran a .30 over 1977 block, home ported D3's with Comp roller tip rockers with guide plates, Cam was Lunita .516 lift intake and .543 lift exhaust and I believe 110 LC. . 750 Edelbrock and performer intake. At the drags first time out turned 14.5 1/4 mile in my 1964 4 door International Truck.
